[gdal-dev] gdaltransform - output into textfile
Even Rouault even.rouault at mines-paris.org
Thu Oct 25 11:00:02 PDT 2012
Le jeudi 25 octobre 2012 09:33:38, Ernest Menville a écrit :
> But is it not the main purpose of gdaltransform to transform a lot of
> points into another coordinate system? How can I do that, if it is not
> possible to save the output coordinates into a text file? (...without
> copy&paste in the command line, what is just feasible for a small number of
> points)
For the record, unfortuanetely it won't help you much, but I don't reproduce
the issues you're facing. The gdaltransform -s_srs EPSG:4326 -t_srs EPSG:3857
< "WGS84.txt" >"Grid.txt" command just works fine for me. Perhaps an issue with
your setup ?
