[gdal-dev] Question about using crop_to_cutline
Even Rouault even.rouault at mines-paris.org
Thu Oct 25 11:09:34 PDT 2012
Le mercredi 24 octobre 2012 17:19:45, António Rocha a écrit :
> Greetings
> I have a raster image and a shapefile polygon and I wanted to crop the
> raster for just to have valid pixels inside the polygon. I have used
> crop_to_cutline but here is a problem:
> It produces a raster map but pixels does not geographically match with
> the original raster map. So, i produce a raster map but I'm not able to
> compare with original image since there is a small displacement. How can
> I obtain a raster map without this mismatch?
This is the very same topic that is discussed in
http://trac.osgeo.org/gdal/ticket/3947 . There's no solution to your problem,
but some background discussion that explains the current behaviour.
> Thank you
> Regards,
> Antonio
> GDAL version 1.9.1
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
