[gdal-dev] Removing Nodata pixels from raster
Volker Wichmann Volker.Wichmann at uibk.ac.at
Fri Oct 26 08:33:56 PDT 2012
In SAGA GIS there is a "Crop to Data" module (in Grid Tools module
library), which performs the task.
But this would require you to import your Geotif with the GDAL import
module, process it in SAGA, and finally export it as Geotif again with
the GDAL export module.
Best regards,
Volker
On 10/25/2012 05:32 PM, katrin eggert wrote:
> Hello
> No I don't know where my valid pixels are.
> Any alternative?
> 2012/10/25 Kyle Shannon <kyle at pobox.com>
>> Katrin,
>> Do you know where you valid pixels are in the image?  If so,
>> gdal_translate with -srcwin would work:
>> kyle at ubuntu:~$ gdal_translate -srcwin xoff yoff 60 100 in.tif out.tif
>> where xoff, yoff are the number of pixels from the image origin that your
>> valid region begins(pixels, lines).  See
>> http://gdal.org/gdal_translate.html for more info.
>> On Thu, Oct 25, 2012 at 8:05 AM, katrin eggert <katrineggert1980 at gmail.com
>>> wrote:
>>> Greetings
>>> I have a Geotif with only one Layer with a size of 6000x5000 but from
>>> which I only have a square of 60x100 with bvalid pixels. the remaining are
>>> NOdata. The problem is that this Geotiff is a big file 90MB and without
>>> these NoData values I would have a much smaller raster.
>>> How can I generate a new Geotiff without these noValid values and with
>>> extent adjusted to the valid pixels?
>>> Thank you
>>> Regards,
>>> Katrin E.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
