[gdal-dev] How to cut a Raster map with a KML file
Luis Lisboa luislisboa1975 at gmail.com
Mon Sep 3 09:04:19 PDT 2012
Greetings
I have a raster file (Geotiff) and I have a KML file with a polygon and I
want to cut raster map to only have valid values inside the polygon. How
can I do this using just GDAL?
Usually I used to cut geotiff file with gdalwarp and but in those cases I
was cutting a square (xmin xmax ymin ymax) and in this case is a more
complex polygon
Thanks
Regards,
Luis
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120903/167236b4/attachment.html>
