[gdal-dev] How to cut a Raster map with a KML file
Luis Lisboa luislisboa1975 at gmail.com
Tue Sep 4 06:53:19 PDT 2012
Thank you Chitanya. But it created an output file with two layers (one with
the values from original file and another with a 255 for the pixels thar
are inside KMZ file: How can I have just one layer?
Other thing: as far as I saw it procewssed the data without needing to have
the KML and the Geotiff in the same CRS. Can anyone confimr that this is
true?
Thanks
Luis
On Mon, Sep 3, 2012 at 5:10 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Luis,
> gdalwarp has some options for this exact purpose.
> The cutline can be from any of the OGR readable datasource.
> http://www.gdal.org/gdalwarp.html
> On Mon, Sep 3, 2012 at 9:34 PM, Luis Lisboa <luislisboa1975 at gmail.com>wrote:
>> Greetings
>> I have a raster file (Geotiff) and I have a KML file with a polygon and I
>> want to cut raster map to only have valid values inside the polygon. How
>> can I do this using just GDAL?
>> Usually I used to cut geotiff file with gdalwarp and but in those cases I
>> was cutting a square (xmin xmax ymin ymax) and in this case is a more
>> complex polygon
>> Thanks
>> Regards,
>> Luis
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120904/7b1b31a2/attachment.html>
