[gdal-dev] Remove mentions to FWTools from GDAL wiki ?
Even Rouault even.rouault at mines-paris.org
Wed Sep 5 03:08:11 PDT 2012
I notice that we have regularly reports from users that still use FWTools 2.4.7
and run into problems that are often solved by using more recent versions. I'd
suggest we remove mentions to FWTools from
http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries .
Frank,
Perhaps a prominent notice should be added to http://fwtools.maptools.org/ to
indicate that the available binaries correspond to obsolete versions and point
to http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries ? And mentions to
"latest and greatest" removed
Best regards,
Even
