[gdal-dev] GEOS Ver 3.3.5 and GDAL Ver 1.91
Kyle Shannon kyle at pobox.com
Wed Sep 5 13:16:14 PDT 2012
Martin,
Did you by chance use cmake to build geos?  I built 1.9.1 against geos
3.3.5, but used cmake when building geos.  It appears the output files are
named differently when cmake is used.  If you did use cmake, then it looks
like you need to specify:
GEOS_LIB = $(GEOS_DIR)/lib/geos_c.lib
if normal nmake was used without cmake generated files then it appears
geos_c_i.lib is the proper lib.
kss
On Wed, Sep 5, 2012 at 2:04 PM, Martin Chapman <chapmanm at pixia.com> wrote:
> I love this user group.  Thanks Joaquim!
> Best regards,
> Martin
> *From:* Joaquim Luis [mailto:jluis at ualg.pt]
> *Sent:* Wednesday, September 05, 2012 2:03 PM
> *To:* Martin Chapman
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] GEOS Ver 3.3.5 and GDAL Ver 1.91
> On 05-09-2012 20:33, Martin Chapman wrote:
> All,
> I am trying to compile GDAL 1.91 with GEOS version 3.3.5 on windows 7 x64
> and the nmake.opt file does not seem to match the directory structure of
> the latest GEOS.  Am I missing something simple?  Any help is much
> appreciated.
> Muchos gracias,
> Martin
> Martin,
> I have built GDAL trunk recently with GEOS 3.3.5 with no problems, but I
> use a name coding for the dir where the libs are stored.
> For example, for GEOS I have in my nmake.local
> GEOS_DIR = C:\programs\compa_libs\geos-3.3.5\compileds
> GEOS_CFLAGS = -I$(GEOS_DIR)/$(LIB_CC)/include -DHAVE_GEOS
> GEOS_LIB     = $(GEOS_DIR)/$(LIB_CC)/lib/geos_c_i.lib
> where $(LIB_CC) translates to
> VC10_64 or VC10_32
> depending whether I'm building 32 or 64 bits versions
> Off course, when I compiled GEOS, I stored the libs in
> $(GEOS_DIR)/$(LIB_CC)/lib and the headers in $(GEOS_DIR)/$(LIB_CC)/include
> Joaquim
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120905/cfc526e8/attachment.html>
