[gdal-dev] Odd behavior with OGR2OGR and arcSDE - tries to copy multiple layers.
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Sep 5 21:50:54 PDT 2012
Phil,
Try the same command with the ArcSDE layer name specified at the end for
ogr2ogr.
On Thu, Sep 6, 2012 at 4:41 AM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> If I copy a set from sde to postgis with:
> ogr2ogr -f "PostgreSQL" PG:"host=myhost user=myuser dbname=mydb
> password=************** port=5432" -nln postgis_name
> SDE:SDE,5151,,*******,****,sde_name
> then the process works but then it comes with a message
> FAILED: layer aready exists and -append not specified, but reports that
> it is trying to copy a completely different layer from the one specified
> in SDE. It is a valid sde layer. If I put -overwrite switch in, then
> something even more curious happens. It appears to go through all the
> layers in sde and one by one replaces the postgis layer with each (I
> discovered by interrupting the process or looking at data in postgis).
> I am using GDAL from stable version of MS4W, with the sde dlls for
> arcSDE 9.3
> Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
> Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477
> 5232
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose the
> contents.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120906/d6763de0/attachment.html>
