[gdal-dev] How to get a working version of gdal_retile.py?
Paul Meems bontepaarden at gmail.com
Thu Sep 6 00:47:36 PDT 2012
Even,
Thanks again. That was the problem.
I uninstalled Python and installed the 32-bit version.
Next I uninstalled GDAL-1.9.1.win32-py2.7 and installed it again.
Now my Python installation is found.
My ecw file is now being tiled.
If you are ever in The Netherlands I'll by you a beer!
Thanks,
Paul
2012/9/6 Even Rouault <even.rouault at mines-paris.org>
> Selon Paul Meems <bontepaarden at gmail.com>:
> > Thanks Even for all your help.
> > But I'm still having trouble.
> You've downloaded a 64-bit version of python (python-2.7.3.amd64.msi), and
> are
> trying to use it with a 32-bit build of that GDAL Python bindings
> (GDAL-1.9.1.win32-py2.7.msi). That can't work.
> Either you use 64-bit Python and 64-bit GDAL, or 32-bit Python with 32-bit
> GDAL.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120906/fa928c08/attachment-0001.html>
