[gdal-dev] GEOS Ver 3.3.5 and GDAL Ver 1.91
Martin Chapman chapmanm at pixia.com
Thu Sep 6 12:09:51 PDT 2012
That worked.  Thanks for all your help.
Martin
Sent: Wednesday, September 05, 2012 2:16 PM
To: Martin Chapman
Cc: Joaquim Luis; gdal-dev at lists.osgeo.org; outramk at pixia.com
Subject: Re: [gdal-dev] GEOS Ver 3.3.5 and GDAL Ver 1.91
Martin,
Did you by chance use cmake to build geos?  I built 1.9.1 against geos
3.3.5, but used cmake when building geos.  It appears the output files are
named differently when cmake is used.  If you did use cmake, then it looks
like you need to specify:
GEOS_LIB = $(GEOS_DIR)/lib/geos_c.lib
if normal nmake was used without cmake generated files then it appears
geos_c_i.lib is the proper lib.
kss
On Wed, Sep 5, 2012 at 2:04 PM, Martin Chapman <chapmanm at pixia.com> wrote:
I love this user group.  Thanks Joaquim!
Best regards,
Martin
Sent: Wednesday, September 05, 2012 2:03 PM
To: Martin Chapman
Cc: gdal-dev at lists.osgeo.org
On 05-09-2012 20:33, Martin Chapman wrote:
All,
I am trying to compile GDAL 1.91 with GEOS version 3.3.5 on windows 7 x64
and the nmake.opt file does not seem to match the directory structure of
the latest GEOS.  Am I missing something simple?  Any help is much
appreciated.
Muchos gracias,
Martin
Martin,
I have built GDAL trunk recently with GEOS 3.3.5 with no problems, but I
use a name coding for the dir where the libs are stored.
For example, for GEOS I have in my nmake.local
GEOS_DIR = C:\programs\compa_libs\geos-3.3.5\compileds
GEOS_CFLAGS = -I$(GEOS_DIR)/$(LIB_CC)/include -DHAVE_GEOS
GEOS_LIB     = $(GEOS_DIR)/$(LIB_CC)/lib/geos_c_i.lib
where $(LIB_CC) translates to
VC10_64 or VC10_32
depending whether I'm building 32 or 64 bits versions
Off course, when I compiled GEOS, I stored the libs in
$(GEOS_DIR)/$(LIB_CC)/lib and the headers in $(GEOS_DIR)/$(LIB_CC)/include
Joaquim
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120906/44dca05f/attachment.html>
