[gdal-dev] Can't delete feature from shapefile in python
Hugo hfpmartins at gmail.com
Fri Sep 7 20:06:41 PDT 2012
Hello all,
I'm trying to delete a number of records from shapefile based on an
attribute. The strange thing that is happening is that feature count never
changes but if i make the same filter a second time the features are no
longer there. The code i'm using is below. I should be doing something
wrong for sure.
import os
from osgeo import ogr
path = 'C:\\datasets'
os.chdir(path)
shp = ogr.Open('locais.shp',1)
layer = shp.GetLayer(0)
print layer.GetFeatureCount()
layer.SetAttributeFilter('name ilike "nacional%"')
feat = layer.GetNextFeature()
while feat:
    featId = feat.GetFID()
    layer.DeleteFeature(featId)
shp.Destroy()
Any suggestions? Thanks in advance.
Regards,
Hugo Martins
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120908/b7dccac3/attachment.html>
