[gdal-dev] Layer creation option FID (Spatialite, MSSQL)
Tamas Szekeres szekerest at gmail.com
Mon Sep 10 03:16:03 PDT 2012
2012/9/10 Jeremy Palmer <JPalmer at linz.govt.nz>
> Any limiting factors in improving the Spatialite and MSSQLSpatial drivers
> to allow defining the feature ID column LCO like the PostgreSQL (FID) or
> FileGDB (OID_NAME) drivers?
Yes it could be implemented. The limiting factor is the available spare
time ;-)
> Also, do Spatialite, MSSQL user defined tables with PKs already set work
> correctly in OGR?
What do you mean by "working correctly"? Did you find issues?
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120910/a4c6933a/attachment.html>
