[gdal-dev] ECW support on Fedora Linux - error
lanufabi dasfabirad at googlemail.com
Tue Sep 11 09:42:28 PDT 2012
 In reply to this post by jkadlec
Hey,
I compiled libecwj2 and gdal 1.9.1 on arch linux like "jkadlec" did and get
the same error when i use gdalinfo for ecw files:
terminate called after throwing an instance of 'std::length_error' what():
basic_string::_S_create
gdalinfo --formats puts out that ECW is supported.
What can I do to identify the problem? Do you know a solution?
Thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/ECW-support-on-Fedora-Linux-error-tp4991388p5001142.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
