[gdal-dev] gdalwarp and Natural Earth
Pierre GIRAUD pierre.giraud at gmail.com
Sat Sep 15 12:01:10 PDT 2012
Hello all,
A new "Natural Earth" projection was added recently to the PROJ.4 library.
http://www.shadedrelief.com/NE_proj/
I'm trying to figure out if and how it is possible to transform a
raster file (GeoTIFF) using this projection.
I've tried the following unsuccessfully:
gdalwarp -t_srs '+proj=natearth' -s_srs EPSG:4326 map_4326.tif map_natearth.tif
ERROR 1: Translating source or target SRS failed:
+proj=natearth
Does GDAL have support for this projection? Does it rely on PROJ for
that purpose? Should I have something to be configured specifically
while compiling it?
Thanks for your help.
Pierre
  | Pierre GIRAUD
  | http://pierrelebricoleur.blogspot.com
  | http://www.flickr.com/photos/pierregiraud
