[gdal-dev] How to publish null as nodata by gdalwarp?
OHTSUKA Ko-hei kochizufan at gmail.com
Sun Sep 16 22:12:24 PDT 2012
Hello,
I have a GeoTiff DEM, which is written in WGS84 and describes nodata as null.
(No data means sea area.)
I want to make shaded-color-relief tiff in spherical mercator from it, so I run:
gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3785 -r bilinear wgs_dem.tif merc_dem.tif
gdaldem color-relief -alpha -co ALPHA=YES merc_dem.tif ramp.txt merc_rel.tif
gdaldem hillshade -compute_edges merc_dem.tif melc_shd.tiff
hsv_merge.py merc_rel.tif melc_shd.tiff melc_shdrel.tiff
But, result file melc_shdrel.tiff not contains null data.
null data are all changed into value 0, so they are not transparent,
and colored as ground.
I tried several change to command, consequently,
gdalwarp -s_srs EPSG:4326 -t_srs EPSG:3785 -srcnodata "" -r bilinear
This command makes null data not to value 0 but to -9999.
"gdaldem color-relief" detect this change and make sea area as transparent.
But, "gdaldem hillshade" not detect this, so sea shore shown as huge
cliff, and sea area became
gray.
I tried '--dstnodata' or '-dstalpha' option, but they makes any good change.
Is there any ways to get destination data which describes null as
nodata in gdalwarp?
Or, making "gdaldem hillshade" to detect -9999 as nodata?
Regards,
OHTSUKA Ko-hei
