[gdal-dev] s57 layers
Neelima Emmani neelima.emmani at iictechnologies.com
Fri Sep 21 00:15:25 PDT 2012
Hi Hilda,
I gave system variables the path where my *.csv files are. But even then the situation is same. Is there any other help you can suggest me.
With Regards,
Neelima Emmani
GIS Developer
Phone Number - 04039144487
Mobile Number - 9490817875
From: Hilda Villegas [hilda.villegas at navico.com]
Sent: Friday, September 21, 2012 11:00 AM
To: Neelima Emmani; gdal-dev at lists.osgeo.org
Subject: RE: s57 layers
Hi Neelima,
I was dealing with the same issue some time ago, you have to add a system variable called GDAL_DATA pointing to the s57 .CSV files location (you can find them in the data folder. You will need s57attributes.csv, s57objectclasses.csv and s57expectedinput.csv at least) unfortunately these files are not updated with the latest changes from IHO, so all updates from S-57 Supplement No 1 and No 2 to Edition 3.1 are not reflected into the .CSV files.
I hope this helps.
Best Regards,
HILDA VILLEGAS
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Neelima Emmani
Sent: Thursday, September 20, 2012 9:59 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] s57 layers
Hi All,
I am trying to load s57 dataset into a windowform using C# coding. The datasoruce is read well. But the layers are not presented properly. Layers are shown as below instead of layers like ACHARE, BCNSPP.....
[cid:image001.png at 01CD977E.B0F45B10]
Actually I have 49 layers in my map.Can anyone tell me why is this happening?Any help is appreciated.
With Regards,
Neelima Emmani
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120921/db958a9e/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120921/db958a9e/attachment-0001.png>
