[gdal-dev] Wanted: -lco DIM for OGR/SQLite driver
Even Rouault even.rouault at mines-paris.org
Fri Sep 21 13:00:48 PDT 2012
Le vendredi 21 septembre 2012 17:01:12, Jukka Rahkonen a écrit :
> Hi,
> OCI and PostgreSQL drivers both have layer creation option for setting
> layer dimensions and it would be nice to have DIM option also in
> Spatialite driver. What I was missing today was a possibility to use -lco
> DIM=2 and convert 3D coordinates with all zero Z values into 2D
> coordinates. Spatialite itself seems to support XY, XYM, XYZ and XYZM
> dimensions.
Actually, instead of adding this option in every driver, I've added a -dim
option at ogr2ogr level. This will affect the layer geometry type, and the
geometries inserted.
ogr2ogr poly2d.sqlite poly3d.shp -f sqlite -dsco spatialite=yes -dim 2
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
