[gdal-dev] gdal_polygonize.py
Etienne Tourigny etourigny.dev at gmail.com
Sun Sep 23 18:37:30 PDT 2012
make sure your LD_LIBRARY_PATH and PATH point to your custom
directories BEFORE system directories.
like export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
Also removing system package should help, but it's not necessary if
your setup if correct.
Etienne
On Sun, Sep 23, 2012 at 5:08 PM, Jeff Lake <admin at michiganwxsystem.com> wrote:
> Yes I can ..
> but have a feeling its running 1.8.0 I installed earlier from RPM
> is there going to be a 1.9.1 RPM for el5 ??
> -Jeff Lake
> MichiganWxSystem.com
> AllisonHouse.com
> TheWeatherCenter.net
> GRLevelXStuff.com
> On 9/23/2012 15:59, Etienne Tourigny wrote:
>> Also, can you run any of the executables like gdalinfo?
>> On Sun, Sep 23, 2012 at 3:02 PM, Even Rouault
>> <even.rouault at mines-paris.org> wrote:
>>> Le dimanche 23 septembre 2012 19:57:50, Jeff Lake a écrit :
>>>> am I missing something here??
>>>> installed gdal 1.9.1 from source
>>>> configure vars ..
>>>> ./configure --with-python --with-geos --with-grass --with-mysql
>>>> but trying to run gdal_polygonize.py
>>>> I get the following
>>>> Traceback (most recent call last):
>>>>     File "/usr/local/bin/gdal_polygonize.py", line 34, in ?
>>>>       import gdal, ogr, osr
>>>>     File
>>>> "/usr/lib64/python2.4/site-packages/GDAL-1.9.1-py2.4-linux-x86_64.egg/gdal.
>>>> py", line 2, in ?
>>>>       from osgeo.gdal import deprecation_warn
>>>>     File
>>>> "/usr/lib64/python2.4/site-packages/GDAL-1.9.1-py2.4-linux-x86_64.egg/osgeo
>>>> /__init__.py", line 24, in ?
>>>>       import _gdal
>>>> ImportError:
>>>> /usr/lib64/python2.4/site-packages/GDAL-1.9.1-py2.4-linux-x86_64.egg/osgeo/
>>>> _gdal.so: undefined symbol: VSIFTruncateL
>>>> this is my first time playing with python... so any pointers
>>> Looks like the Python bindings cannot find libgdal.so (or not the one
>>> from GDAL
>>> 1.9.1, but another GDAL version)
>>> Make sure that the directory of libgdal.so 1.9.1 is in your ld.so.conf or
>>> in
>>> LD_LIBRARY_PATH
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
