[gdal-dev] Row count limit in OGR SQL with -dialect=SQLITE
Even Rouault even.rouault at mines-paris.org
Mon Sep 24 09:27:59 PDT 2012
Selon Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>:
> Hi,
> The following SQL works fine when using Spatialite as source
> osm_data>ogrinfo osm.sqlite -dialect SQLITE -sql "select * from lines
> where highway is not null limit 20"
Note that for a SQLite datasource, -dialect SQLite is useless since the SQL
engine of SQLite is used by default.
> With native OSM data it fails
> OSM_data>ogrinfo -dialect SQLITE finland.osm.pbf -sql "select * from lines
> limit 20"
> Had to open data source read-only.
> INFO: Open of `finland.osm.pbf'
>       using driver `OSM' successful.
> ERROR 1: Too many features have accumulated in points layer. Use
> OGR_INTERLEAVED
> _READING=YES mode
> Why does it fail? Is the error message correct because I can read from
> http://www.gdal.org/ogr/drv_osm.html
> "Note : the ogr2ogr application has been modified to use that
> OGR_INTERLEAVED_READING mode without any particular user action."
> Adding --config OGR_INTERLEAVED_READING YES to ogrinfo request does not lead
> to
> desired result either
It fails because in the ExecuteSQL() method of the OSM driver there's some logic
to parse the SQL statement and extract the table names that are mentioned in it.
The OSM driver then knows which tables it must ignore to avoid them being filled
up with features that will not be consumed and will accumulate.
The issue is that your SQL request isn't understood by the OGR SQL engine due to
the presence of the LIMIT clause, so the above mentionned trick isn't used and
points are accumulated into the points layer until it reaches an error
threshold.
I'm not sure how to fix that. Please file a ticket about it.
(So the error message is correct, but it is more aimed at developers than
end-users, since setting OGR_INTERLEAVED_READING=YES isn't sufficient per se,
but also requires that the code regularly "consumes" features that are filled in
other layers.)
