[gdal-dev] Gdaltindex with -t_srs and Mapserver
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Thu Sep 27 02:07:16 PDT 2012
I had a try with gdaltindex and the new -t_srs option that is discussed in
http://trac.osgeo.org/gdal/ticket/4773. It seems to be as Even was thinking in
the very beginning and Mapserver does not work with tileindex which is
containing reprojected bounding boxes. Images with BBOX in the native projection
are shown but not the others. This line appears into Mapserver log:
msDrawRasterLayerGDAL(): Error in overlap calculation.
It might indeed be good to emit a warning about Mapserver incompability. It
would be very nice if Mapserver supports this kind of tileindeces.
-Jukka Rahkonen-
