[gdal-dev] Setting CS for FileGDB layers
Jeremy Palmer JPalmer at linz.govt.nz
Sun Sep 30 11:01:55 PDT 2012
Sorry my bad. I was still calling MorphToESRI on my cs object before creating the layer. Everything is working great now.
________________________________________
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jeremy Palmer
Sent: Monday, 1 October 2012 6:51 a.m.
To: Even Rouault; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Setting CS for FileGDB layers
Wow Even - thanks for the fix. Your response on this list amazes me.
I just tested creating FileGDB layers for the NZ CS's again. Most of the common ones now work using the EPSG Id :) However I still get failures on these:
2111    PROJCS  NZGD_2000_Wanganui_Circuit
2113    PROJCS  NZGD_2000_Wellington_Circuit
2114    PROJCS  NZGD_2000_Collingwood_Circuit
2125    PROJCS  NZGD_2000_Gawler_Circuit
27215  PROJCS  NZGD_1949_Nelson_Circuit
27216  PROJCS  NZGD_1949_Karamea_Circuit
27222  PROJCS  NZGD_1949_Okarito_Circuit
27227  PROJCS  NZGD_1949_Lindis_Peak_Circuit
27231  PROJCS  NZGD_1949_North_Taieri_Circuit
I checked the ArcGIS WKT definitions and they all have the correct AUTHORITY EPSG id set. Maybe a FileGDB API database issue?
Cheers
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
