[gdal-dev] gdalwarp problem(s)
Reynolds, Scott scott at agi.com
Wed Apr 3 11:36:14 PDT 2013
I've downloaded the file 27002570PAS_dem.zip from ftp://pamap.pasda.psu.edu/pamap_lidar/cycle1/DEM/South/2008/20000000/ and have attempted to warp the data to WGS84 using gdalwarp.  The output should be around 75W but is being warped to 91W.  I'm using gdalwarp 1.9.2 which was installed as part of OSGeo4W.  Any ideas?
Thanks,
Scott
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130403/521c9a34/attachment-0001.html>
