[gdal-dev] 1.9.2 csharp and python interfaces
Tamas Szekeres szekerest at gmail.com
Wed Apr 3 11:51:54 PDT 2013
What is the MSVC and the SWIG version are you using?  I confirm
MSVC2003/2005/2008/2010 + SWIG1.3.39 compiles successfully.
Best regards,
Tamas
2013/4/3 Finegan Thomas-QTF001 <t.finegan at motorolasolutions.com>
>  Hello,****
> On Windows, none of the swig interfaces are built with the default target.
> I have to “cd swig” then run nmake from there. Is there a reason the C# and
> other wrappers are not built by default?****
> On Windows, when I run nmake from the swig directory I get:****
> osr\OsrPINVOKE.cs(192,10): error CS0111: Type 'OSGeo.OSR.OsrPINVOKE'
> already****
>         defines a member called 'OsrPINVOKE' with the same parameter types
> osr\OsrPINVOKE.cs(188,10): (Location of symbol related to previous error)*
> Please help me fix the problem with OsrPINVOKE being defined twice.****
> Thank you,****
> Tom****
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130403/b4024827/attachment.html>
