[gdal-dev] GDAL/OGR C# wrapper and UTF8
rburhum ragi at burhum.com
Wed Apr 3 12:17:16 PDT 2013
Hello Tamas and Dennis,
This is my personal opinion and there may tons of people that disagree, but
I think it is more sane to always assume UTF8 encoding. There is
functionality among the various drivers to accept/return strings in
different encodings (through the CPL_Recode mechanism) but they all do it
with different parameters (e.g. "PGCLIENTENCODING" in PostgreSQL,
"SHAPE_ENCODING" in ESRI Shapefiles, etc). Overly complicated for
programmatic access.
Strings being set should use UTF8 encoding. Strings being read should assume
UTF8 encoding. Not sure about the column names, layer names and such, but I
would rather find the drivers that are not assuming utf8 and fix those than
doing some extra complicated magic in the C# bindings. It simplifies logic
greatly.
If the underlying data store is using Windows-1252 encoding internally, that
should be handled and abstracted out by the driver itself (by doing the
conversions into utf8), not the bindings.
My two cents,
- Ragi
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-GDAL-OGR-C-wrapper-and-UTF8-tp5044028p5044395.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
