[gdal-dev] PGRasterDataset taking too much time to Open Dataset
Even Rouault even.rouault at mines-paris.org
Thu Apr 4 05:54:41 PDT 2013
Selon ryagz <raghavendra at vizexperts.com>:
> I am new to rising a ticket, i tried logging in with my osgeo.org(the current
> mailing list) credentials but its not logging in. Which credentials should i
> use or should i register separately somewhere to raise a ticket in
> http://trac.osgeo.org/gdal/report/1?asc=0&sort=ticket ?
Yoiu need to have a OSGeo userid that you can create from the link provided in
www.osgeo.org/osgeo_userid
Then go to http://trac.osgeo.org/gdal/newticket and login with the account
created above.
> Thanks,
> Ryagz
http://osgeo-org.1560.n6.nabble.com/PGRasterDataset-taking-too-much-time-to-Open-Dataset-tp5044549p5044556.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
