[gdal-dev] Compile GDAL/OGR with SOSI support
Graeme B. Bell grb at skogoglandskap.no
Mon Apr 8 06:50:47 PDT 2013
Hi there
> Can somebody give me a hint on how to compile GDAL/OGR with support for the
> Norwegian SOSI format?
Not sure about this since I haven't done it myself, but some things to investigate would be:
1
grep -r "sosi" in the source. For me, with the svn version of gdal, this brings up:
nmake.opt:#SOSI_INC_DIR = e:/sosi
nmake.opt:#SOSI_LIBS = e:/sosi/FYBA.lib e:/sosi/GM.lib e:/sosi/UT.lib
you could edit it to reflect your local libraries and try again.
2
http://trac.osgeo.org/gdal/ticket/3638
"	• To actually include SOSI support on windows you will have to edit the makefile.vc files in ogrsf_frmts to include:
		• "sosi" in DIRLIST
		• "sosi\*.obj" and the three FYBA .lib files in the "lib" list
	• and ogrsf_frmts/generic to include:
		• "-DSOSI_ENABLED" in BASEFORMATS (or make it optional)"
Did you do this?
3
Save the compiler output to a log and grep for 'sosi' to see if an error is preventing the compile.
4
Contact the devs directly, ask for advice. Create an account on trac, file a bug, or message them directly.
In particular, 'relet' may be able to walk you through whatever he/she did to build it on linux, if you ask nicely.
Graeme.
> Message: 4
> Date: Mon, 8 Apr 2013 04:16:22 -0700 (PDT)
> From: SBL <Stefan.Blumentrath at nina.no>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Compile GDAL/OGR with SOSI support
> Message-ID: <1365419782783-5045207.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi
> I tried to find a solution in http://trac.osgeo.org/gdal/ticket/3638 as good
> as I can, but without success...
> I do have the (binary version of the) fyba library, but there is no
> --with-sosi option (neither in GDAL 1.8 nor 1.9) when configuring GDAL...
> I also tried:
> CFLAGS="-DSOSI_ENABLED" ./configure
