[gdal-dev] Feature request: gauss and other interpolations in gdalwarp
Even Rouault even.rouault at mines-paris.org
Tue Apr 9 11:34:40 PDT 2013
Le mardi 09 avril 2013 19:06:28, Etienne Tourigny a écrit :
> I have committed new warping methods average and mode to trunk, this will
> be part of gdal-1.10
Hi Etienne,
It would be good if you could extend the autotest suite to add tests for those
new warping methods. For that, you can likely take inspiration from the first
tests of autotest/warp/warp.py. "Reference" images based on utmsmall.tif
reference image is a bit big, but you can likely start from a smaller source
image like byte.tif instead that will produce reference images of reasonable
size to be put in svn.
Regarding nAlgo == 2 (mode with foating point data), the allocations of
pafVals and panSums have the potential to fail if warping is done on a large
image whose floating point values are rarely identical. So I think that
VSIRealloc shoud be used instead with a test on the result to fail properly.
I'm also a bit doubtfull about the practical usefulness of this case on real
data. There might also be a performance issue due to the loop "//Check array
for existing entry" that is at the most inner level of the algorithm. Unless
you have a practical use case, my personnal opinion would be to refuse to run
mode resampling on floating point data, or implement it with a tolerance
parameter to avoid strict floating point comparison (if that makes sense), but
even that wouldn't guarantee reasonable performance and memory consumption.
As far as mode resampling is concerned, it would likely run correctly for
images with color tables, so I believe that the warning in gdalwarp.cpp at
line 1048 could be shut down in that case too (in addition to nearest
resampling)
Best regards,
Even
