[gdal-dev] Compile GDAL/OGR with SOSI support
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Apr 12 05:32:34 PDT 2013
Hello Stefan,
Maybe you can document your steps on the GDAL BuildHints wiki
(http://trac.osgeo.org/gdal/wiki/BuildHints) - create a new page in the
"External Library Issues" section.  Emails are long forgotten (hard to
find), but creating a wiki page will make it easy for others to follow
your great steps.
-jeff
On 2013-04-12 6:26 AM, SBL wrote:
> Hi
> New update on this issue:
> Now I finally managed to build GDAL/OGR with SOSI support on Ubuntu 12.04,
> thanks to the Help of Thomas.
> First I compiled the new Version he provided for the FYBA-lib:
> Then some changes in the GNUmakefiles in the GDAL-source were necessary.
> A version with these changes can (at the moment) be found on:
> https://github.com/kartverket/gdal
> So I did:
> Please note that in the GDAL-version above, SOSI-support is allways
> activated.
> It would be great if the changes could be somehow re-integrated into the
> gdal-project, in a modified way which will offer a --with-sosi option on
> ./configure (optimal also with feedback like "SOSI support:   yes/no").
> The SOSI-driver has been successfully tested with recent SOSI-files...
> Cheers
> Stefan
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
