[gdal-dev] OGR OSM-driver unable to open datasource
Ulrich Strötz ustroetz at gmail.com
Sun Apr 14 13:12:29 PDT 2013
I want to read an OSM file with OGR. I use Version GDAL 1.9.1, released 2012/05/15.
To read a SQLITE file works fine:
$ ogrinfo test.sqlite
INFO: Open of `test.sqlite'
      using driver `SQLite' successful.
1: aaa (Point)
When I try to read a OSM File it fails to open the datasource:
$ ogrinfo test.osm
FAILURE:
Unable to open datasource `test.osm' with the following drivers.
  -> ESRI Shapefile
  -> MapInfo File
The OSM file itself is not broken (I opened it in QGIS).
What am I doing wrong?
Thanks,
Uli
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130414/b5d32b8e/attachment.html>
