[gdal-dev] TIFFMergeFieldInfo error when adding overviews to large tiff
Even Rouault even.rouault at mines-paris.org
Tue Apr 16 14:11:22 PDT 2013
Le mardi 16 avril 2013 22:07:52, Eli Adam a écrit :
> Even,
> Thanks for checking into this and the ideas.
I've investigated a bit and I've discovered that while computing overviews,
libtiff constantly switches from TIFF "directories" (main image, first
overview,second overview, etc...). While doing this, it calls each time client
code to install its own TIFF tags (libgeotiff for the geotiff tags, GDAL for the
GDAL specific TIFF tags), but doesn't reset its array of existing tags. So each
time the tags are added again and again, hence the huge memory allocation.
Could you test the attached patch (assuming you build GDAL with internal
libtiff) ?
It would be good if you could also open a ticket in Trac about that issue.
Even
> Eli
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130416/a38789d3/attachment.bin>
