[gdal-dev] R: Re: MODIS reprojection
Rutger kassies at gmail.com
Thu Apr 18 05:27:33 PDT 2013
Hey Laura,
The coordinates you found seem to be geographic (latitude/longitude), not
sinusoidal.
The MOD03 file is still unprojected, sometimes referred to as a swath or
granule. It contains the original sensor scans which dont yet have a defined
projection. It should be used only with other, lower level, swath products
like the MOD02HKM, MOD02QKM etc. I cant be used together with your MxD14A2
product.
The table on this website shows the 'raster type' for most MODIS Land
products:
https://lpdaac.usgs.gov/products/modis_products_table
Your higher level product is already projected (Sinusoidal tiles). I have
downloaded a MYD14A2 hdf and somewhere (with gdalinfo towards the end) there
should be two tags like:
UpperLeftPointMtrs=(1111950.519667,5559752.598333)
LowerRightMtrs=(2223901.039333,4447802.078667)
These are for tile h19v04. If you mention which tile you are using, or point
me to a file (on ftp://e4ftl01.cr.usgs.gov/MOLA/MYD14A2.005/), i wouldnt
mind looking it up for you. Although for your own confidence it would good
if you can replicate it yourself.
Let me know how it works out.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-R-Re-MODIS-reprojection-tp5047949p5047956.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
