[gdal-dev] MODIS reprojection
Etienne Tourigny etourigny.dev at gmail.com
Thu Apr 18 10:55:32 PDT 2013
On Thu, Apr 18, 2013 at 12:10 PM, Rutger <kassies at gmail.com> wrote:
> Hey,
> Etienne Tourigny-3 wrote
> > I use a similar command, without the -a_ullr argument
> And does it then capture the correct corner coordinates? If i run your
> command it does assign the sinusoidal projection, but takes the pixel
> coordinates (eg 0-2048) as the corner coordinates instead of the sinusoidal
> ones.
Actually, I used this with the level-3 tiled products  such as MCD12Q1 or
MCD45A1. Never tried with level-2 or swath products.
Yes the corners are fine, I can convert a few of them to WGS84 and then
stitch them together with gdalwarp.
Etienne
> @Laura,
> Indeed we are talking about different products, sorry for the confusion.
> You
> mentioned in your first email the products MYD14.A2 and MOD14.A2. I thought
> you meant the "MYD14 A2" product, but you attached a "MYD14" product, which
> is different. Its obvious where the confusion comes from. :)
> These are all the fire products:
> MYD14   Aqua    Thermal Anomalies & Fire        Swath   1000m   5 min
> MOD14A2         Terra   Thermal Anomalies & Fire        Tile    1000m   8
> day
> MYD14A2         Aqua    Thermal Anomalies & Fire        Tile    1000m   8
> day
> MOD14A1         Terra   Thermal Anomalies & Fire        Tile    1000m
> Daily
> MYD14A1         Aqua    Thermal Anomalies & Fire        Tile    1000m
> Daily
> MOD14   Terra   Thermal Anomalies & Fire        Swath   1000m   5 min
> The "MOD14" & "MYD14" products are indeed swath, and should be used
> together
> with the MOD03 with the same timestamp.
> I think the best way to process them is by using "MRT Swath" which you can
> download at:
> https://lpdaac.usgs.gov/tools
> MRT Swath is way beyond the scope of this mailing list, but feel free to
> send me a direct email about it if you have questions.
> I have used Pyresample as an alternative which works very well, but
> requires
> the use of Python:
> http://code.google.com/p/pyresample/
> To end with an actual GDAL related solution, there is an option to warp an
> image using gdalwarp and so-called "geolocation arrays". I can get it to
> work with the MODIS swaths, but i dont like the results at all. It is
> previously discussed at:
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-reproject-python-numpy-binary-swath-lat-lon-td4978609.html
> The MODIS swath products arent equally gridded and still contain what is
> called the 'bow-tie' effect. (overlapping scans at high zenith angles). I
> dont know if the GDAL geoloc option is supposed to handle this properly.
> The
> image a posted earlier in the thread mentioned above clearly shows
> artifacts
> which i cannot explain or resolve.
> Regards,
> Rutger
> http://osgeo-org.1560.x6.nabble.com/MODIS-reprojection-tp5047700p5048019.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130418/0115def9/attachment.html>
