[gdal-dev] Missing geometry type when using ogr2ogr to write FileGDB
Stefan Keller sfkeller at gmail.com
Sun Apr 21 10:10:49 PDT 2013
Many thanks for the quick reply, Even!
You're right, it seems to work with Shapefile - but not for the WFS reader
(and own server) we are testing...
Below you find the GML output of our WFS source.
So is the "fault" in the WFS reader - or even in our WFS Response XML?
Yours, Stefan
Testing OpenPOIMap WFS Service
Get all hostels of Switzerland from OpenStreetMap database
("tourism=hostel"). Response edited:
GetCapabilities:
http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E&SERVICE=WFS&REQUEST=GetCapabilities
Response => (...)
GetFeature:
http://openpoimap.ch/featureserver/workspace.cgi?key=HG4kFX2kEEqBSqvcswuh2E&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=pois&SRSNAME=EPSG:4326
Response =>
<wfs:FeatureCollection
  xmlns:fs="http://example.com/featureserver"
  xmlns:wfs="http://www.opengis.net/wfs"
  xmlns:gml="http://www.opengis.net/gml"
  xmlns:ogc="http://www.opengis.net/ogc"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengeospatial.net//wfs/1.0.0/WFS-basic.xsd">
  <gml:featureMember gml:id="-324390">
    <fs:pois fid="-324390">
      <fs:way>
        <gml:Point srsName="EPSG:4326">
          <gml:coordinates decimal="." cs="," ts="
">6.59728931318,46.5195096642</gml:coordinates>
        </gml:Point>
      </fs:way>
      <fs:shop>None</fs:shop>
      <fs:amenity>None</fs:amenity>
      <fs:surface>None</fs:surface>
      <fs:street>None</fs:street>
    </fs:pois>
  </gml:featureMember>
</wfs:FeatureCollection>
2013/4/21 Even Rouault <even.rouault at mines-paris.org>
> Le dimanche 21 avril 2013 17:49:28, Stefan Keller a écrit :
> > When trying to use ogr2ogr (ver. 1.9) to convert a Shapefile (geometry
> type
> > Polygon) to file geodatabase (FileGDB) I'm getting an error like "FGDB
> > layers cannot be created with a wkbUnknown layer geometry type.":
> > $ ogr2ogr -f filegdb out.gdb polygon.shp
> > When adding -nlt it seems to work:
> > $ ogr2ogr -f filegdb out.gdb polygon.shp -nlt POLYGON
> > This is to a) an usual OGR behavior, and b) a show stopper for my script
> > because I don't know before hand (and won't check with ogrinfo) what
> > geometry type the input source is. Seems like there is a problem in the
> > FileGDB driver.
> > Can anybody confirm and explain this bug?
> Stefan,
> I don't confirm that behaviour with either 1.9.2 or 1.10.0. Conversion
> works
> fine for me without specifying -nlt. What is the geometry type reported by
> ogrinfo on polygon.shp ?
> Even
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130421/6620646f/attachment.html>
