[gdal-dev] Missing geometry type when using ogr2ogr to write	FileGDB
    Stefan Keller
    sfkeller at gmail.com
    Sun Apr 21 16:15:56 PDT 2013
Ok. I now see it's something which can be corrected at the WFS server side
[1].
In Mapserver one can configure:
  gml_geometries "geometry"
  gml_geometry_type "polygon"
... to set the geometry type explicitly to type="gml:polygonPropertyType".
Yours, Stefan
[1]
http://osgeo-org.1560.x6.nabble.com/UMN-MAPSERVER-DEV-change-in-WFS-DescribeFeatureType-response-MS-4-6-td4309674.html
2013/4/21 Even Rouault <even.rouault at mines-paris.org>
> > > There's nothing wrong in the GetFeature output. It is completely
> > legitimate
> > > and usual to have a gml:Box inside a gml:boundedBy.
> > > The DescribeFeatureType is also valid, but it could be made more
> specific
> > by
> > > reporting type="gml:SurfacePropertyType" instead of
> > > type="gml:GeometryPropertyType"
> > I see.
> > To me GetCapabilities of http://http://maps.zh.ch/wfs/FnsNSWFS should
> also
> > be more specific. Currently there's no geometry hint (and it even issues
> > warnings about missing EXTENT).
> > So,given it's DescribeFeatureType would report
> > type="gml:SurfacePropertyType" would the WFS reader of GDAL work?
> Yes (well, to be pedantic, it does already work currently)
> > I thought, most WFS clients/converters read GetCapabilities, not
> > DescribeFeatureType.
> The output of GetCapabilities cannot be used to guess the layer geometry
> type,
> since there's no element to indicate it. You have to read the output of
> DescribeFeatureType for that (or fallback to the features themselves).
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130422/45c9de27/attachment-0001.html>
