[gdal-dev] Geopdf dependency on Poppler and Visual Studio 2012
Jeff Lacoste jefflacostegdal at gmail.com
Thu Apr 25 07:07:05 PDT 2013
I'm trying to build GDAL using Visual Studio 2012 and run into an issue
with Geopdf format.
This format depends on Poppler (or podofo) 3rd party component.
Is there a VS 2012 compatible Poppler library for win32 and x64 bits ?
I downloaded the Poppler library from http://vbkto.dyndns.org:1280/sdk/ but
it appears
to be a static .lib built using Visual Studio 2010. If it was a stub .lib
(with run time .dll) I can
consume it from Visual Studio 2012, but its unfortunately a static .lib
(that VS 2012 can not link without errors).
Thanks
Jeff
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130425/84ec4148/attachment.html>
