[gdal-dev] create only line shapefile
maning sambale emmanuel.sambale at gmail.com
Thu Apr 25 19:25:29 PDT 2013
Thanks Jukka!  Works flawlessly and it seems to be much faster even
with the clipping.
On Fri, Apr 26, 2013 at 1:13 AM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi> wrote:
> maning sambale <emmanuel.sambale <at> gmail.com> writes:
>> I have this syntax:
>> ogr2ogr -f "ESRI Shapefile" test_osm.shp philippines.osm.pbf -lco SHPT=ARC \
>> -skipfailures -progress --config OSM_CONFIG_FILE osmconf.ini \
>> -select name,highway,oneway,maxspeed,access,lanes \
>> -where "highway is not null" -clipsrc ph_province.shp \
>> -clipsrcsql "SELECT * FROM ph_province WHERE provname='metro_manila'"
>> I basically want to extract just the highways in the metro_manila polygon.
>> But I still get 4 shapefiles (point, line, multilinestrings,
>> multipolygons, other_relations).
>> Except for the line.shp, all the other shapefiles are empty.
>> I defined -lco SHPT=ARC.
>> How do I just get the lines.shp?
> Try with -sql instead of -select and -where
> -sql "select name, highway, oneway, maxspeed, access, lanes from lines where
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
