[gdal-dev] Use GDAL to combine (rather than mosaic) rasters
Ritvik Sahajpal ritvik at umd.edu
Sun Apr 28 13:54:58 PDT 2013
Is there a GDAL command which can combine multiple rasters so that so a
unique output value is assigned to each unique combination of input values,
like the combine command in ArcGIS?
gdal_merge seems to mosaic rasters so it is not exactly what I need.
thanks!
rit
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130428/43f3f2b3/attachment.html>
