[gdal-dev] Geopdf dependency on Poppler and Visual Studio 2012
Jeff Lacoste jefflacostegdal at gmail.com
Mon Apr 29 06:31:58 PDT 2013
Thanks Even. I'll stick then with 'FreeType' and enable the xpdf headers.
Jeff
On Sun, Apr 28, 2013 at 8:13 AM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Le vendredi 26 avril 2013 14:28:26, Jeff Lacoste a écrit :
> > Thanks Joaquim. I now managed to build Poppler using freetype as its only
> > dependency.
> > Do we know if GDAL GeoPdf driver needs 'Poppler' to be built with other
> > dependencies that can come with Poppler: lcms, icon, openjpeg, tiff, etc.
> > To have Geopdf driver work correctly using 'Poppler' are these
> dependencies
> > needed ? or all it needs is 'Freetype' and 'enable-xpdf-headers' ?
> Technically, the GDAL PDF driver only requires Poppler to be configured
> with
> enable-xpdf-headers to compile against it. The other dependencies will be
> needed depending on the PDF documents you'll read. Freetype seems usefull
> indeed.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130429/6706b9d2/attachment.html>
