[gdal-dev] Build GDAL with OCI support on Linux
Rui Cavaco rcavaco at sig2000.pt
Mon Apr 29 16:12:34 PDT 2013
Hi Ivan, thanks for your quick reply!
Yes, ogrinfo --formats doesn't list OCI.
I'll check the thread in OTN you mentioned, it seems it has something specific about Ubuntu. I'll feedback the results.
Many thanks!
Rui Cavaco
___________________________
SIG2000, Sist. de Infor. Geográfica, Lda.
Rua do Campo Alegre, 1306 Sala 308/107 4150 - 174 Porto
Tel.: + 351 22 606 75 77
Fax: + 351 22 606 75 78
Mail: rcavaco at sig2000.pt
________________________________________
De: Ivan Lucena [ivan.lucena at princeton-ma.us]
Enviado: segunda-feira, 29 de Abril de 2013 21:53
Para: Rui Cavaco; ""
Assunto: Re: [gdal-dev] Build GDAL with OCI support on Linux
Hi Rui,
>  -------Original Message-------
>  From: Rui Cavaco <rcavaco at sig2000.pt>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Build GDAL with OCI support on Linux
>  Sent: Apr 29 '13 15:29
>  Hello!
>  I'm trying to get OCI support in GDAL / OGR in Ubuntu 12.04 32-bit.
>  I've successfully installed Oracle Instant Client 11_2 . SQLPlus works
>  flawlessly.
>  Building GDAL also ended with no errors.
>  But executing ogrinfo --formats, OCI format is not listed.
>  Building script is:
>  export LDFLAGS="-Wl,-no-as-needed"
>  ./configure \
>     --with-python --with-libkml=no --with-geotiff=internal \
>     --with-threads --with-libtiff=internal --with-geotiff=internal
>  --with-jpeg=internal --with-gif=internal --with-png=internal
>  --with-libz=internal \
>     --with-oci=yes \
>  --with-oci-include=/usr/lib/oracle/instantclient_11_2/sdk/include \
>     --with-oci-lib=/usr/lib/oracle/instantclient_11_2
>  make
>  sudo make install
>  Environment variables:
>  LD_LIBRARY_PATH=/usr/local/pgsql/lib:/usr/lib/oracle/instantclient_11_2:/usr/local/lib:
>  PATH=/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/lib/oracle/instantclient_11_2
>  In Config.log, we can see:
>  configure:22485: checking for Oracle OCI headers in
>  configure:22518: g++ -c -g -O2
>  -I/usr/lib/oracle/instantclient_11_2/sdk/include conftest.cpp >&5
>  configure:22518: $? = 0
>  configure:22531: result: yes
>  configure:22552: checking for Oracle OCI libraries in
>  configure:22578: g++ -o conftest -g -O2
>  -I/usr/lib/oracle/instantclient_11_2/sdk/include -Wl,-no-as-needed
>  -L/usr/lib/oracle/instantclient_11_2 -lclntsh conftest.cpp -L/usr/lib
>  -lpq -lpthread -lm -lrt -ldl  >&5
>  configure:22578: $? = 0
>  configure:22582: result: yes
>  configure:22626: checking if Oracle OCI version is >= 10.0.1
>  configure:22646: result: yes
>  configure:22649: checking for Oracle version >= 10.x to use -lnnz10 flag
>  configure:22654: result: yes
>  configure:22675: checking if Oracle support is enabled
>  configure:22689: result: yes
>  configure:24105: checking for Oracle OCI headers in
>  configure:24138: g++ -c -g -O2
>  configure:24138: $? = 0
>  configure:24151: result: yes
>  configure:24172: checking for Oracle OCI libraries in
>  configure:24198: g++ -o conftest -g -O2
>  -L/usr/lib/oracle/instantclient_11_2 -lclntsh conftest.cpp -lexpat
>  -L/usr/lib -lpq -lpthread -lm -lrt -ldl  >&5
>  configure:24198: $? = 0
>  configure:24202: result: yes
>  configure:24246: checking if Oracle OCI version is >= 8.1.7
>  configure:24266: result: yes
>  configure:24269: checking for Oracle version >= 10.x to use -lnnz10 flag
>  configure:24274: result: yes
>  configure:24295: checking if Oracle support is enabled
>  configure:24309: result: yes
>  Apparently, no errors to be found.
>  But OGR tools cannot access Oracle datasources.
What is the command line and the error message that tells you that?
Can you see OCI as one of the driver when you run "ogrinfo --formats" ?
There was a discussion about building GDAL on Ubuntu on OTN:
https://forums.oracle.com/forums/thread.jspa?threadID=1128217&tstart=0&messageID=10658264#10658264
Regards,
Ivan
>  Hoping to get some help on this,
>  Rui Cavaco
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
