[gdal-dev] Vaisala IRIS format driver
Roberto Oliveira Santos roberto at geodev.com.br
Tue Apr 30 08:41:33 PDT 2013
Hello Roger and fellows,
I'm experimenting the new Vaisala IRIS format driver with some of my data
and I have a doubt.
I tried to use it against the volumetric data and it reads all metadata
from file but does not bring any information about reference system, origin
and pixel's size. I think it's correct because I'm reading the raw data
from radar. My question is: how to attach these information to data?
Below I'm sending the output of gdalinfo.
Any feedback would be appreciated.
Kind regards,
Roberto
$ gdalinfo TXS130430143000.RAW2HS1
Driver: IRIS/IRIS data (.PPI, .CAPPi etc)
Files: TXS130430143000.RAW2HS1
Size is 240, 240
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["unnamed ellipse",
        DATUM["unknown",
            SPHEROID["unnamed",6371000,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Azimuthal_Equidistant"],
    PARAMETER["latitude_of_center",0],
    PARAMETER["longitude_of_center",0],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0]]
Origin = (-0.000000000000000,0.000000000000000)
Pixel Size = (0.000000000000000,-0.000000000000000)
Metadata:
  COMPOSITED_PRODUCT=NO
  DATA_TYPE=Data type is not applicable
  DATA_TYPE_CODE=NULL
  DATA_TYPE_INPUT=Data type is not applicable
  DATA_TYPE_INPUT_CODE=NULL
  GROUND_HEIGHT=1016 m
  INGEST_HARDWARE_NAME=...
  INGEST_SITE_IRIS_VERSION=8.12
  INGEST_SITE_NAME=...
  NYQUIST_VELOCITY=6.66 m/s
  PRF=250 Hz
  PRODUCT=RAW
  PRODUCT_CONFIGURATION_NAME=SURV480
  PRODUCT_ID=15
  PRODUCT_SITE_IRIS_VERSION=8.12
  PRODUCT_SITE_NAME=...
  RADAR_HEIGHT=1046 m
  TASK_NAME=SURV480
  TIME_INPUT_INGEST_SWEEP=2013-04-30 14:30:00
  TIME_PRODUCT_GENERATED=2013-04-30 14:30:26
  WAVELENGTH=10.66 cm
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Lower Left  (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Upper Right (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Lower Right (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Center      (   0.0000000,   0.0000000) (  0d 0' 0.01"E,  0d 0' 0.01"N)
Band 1 Block=240x1 Type=Float32, ColorInterp=Undefined
  NoData Value=-9999
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130430/70977e55/attachment-0001.html>
