[gdal-dev] Overflow in geojson values
Dmitriy Baryshnikov bishop.dev at gmail.com
Thu Aug 1 13:54:51 PDT 2013
I really like the RFC31!
Also it'll be great to have a chocie to build GDAL with internal and
external json-c, as libtif, libjpeg, etc. are. And drop patched version
of json-c.
Best regards,
     Dmitriy
02.08.2013 0:36, Frank Warmerdam пишет:
> On Thu, Aug 1, 2013 at 1:32 PM, Even Rouault
> <even.rouault at mines-paris.org <mailto:even.rouault at mines-paris.org>>
> wrote:
>     Selon Dmitriy Baryshnikov <bishop.dev at gmail.com
>     <mailto:bishop.dev at gmail.com>>:
>     > Hi,
>     > GDAL GeoJSON driver use modified and outdated json-c. It seem to
>     me that
>     > this is the bug and ticket in track needed.
>     It would be a 2 step work. I indeed see that newer json-c supports
>     int64, so a
>     first step would be to make the GeoJSON driver uses the new json-c
>     64 bit API.
>     But OGR does not support int64 yet, so the overflow would occur
>     just afterwards.
>     There's an RFC ( http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64 )
>     about that
>     waiting for implementation.
> Folks,
> Also waiting for final refinement and adoption...
> I think I'd like to revisit this issue before the next major release
> since it is negatively impacting a number of drivers - not just geojson.
> Best regards,
> Frank
>     Best regards,
>     Even
>     > Best regards,
>     >      Dmitriy
>     > 01.08.2013 22:31, Smith, Michael ERDC-RDE-CRREL-NH Ð¿ÐžÑ ÐµÑ :
>     > > Unfortunately, that¹s after the data has been read and
>     overflowed.
>     > > The time should be 1375291903959.
>     > > Updated should be 1375295733317.
>     > > Mike
>     > > On 8/1/13 2:21 PM, "Kyle Shannon" <kyle at pobox.com
>     <mailto:kyle at pobox.com>> wrote:
>     > >> On Thu, Aug 1, 2013 at 11:36 AM, Smith, Michael ERDC-RDE-CRREL-NH
>     > >> <Michael.Smith at erdc.dren.mil
>     <mailto:Michael.Smith at erdc.dren.mil>> wrote:
>     > >>> I'm reading a geojson feed put out by the USGS
>     (http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.geojson
>     > >>> but the time/updated values are overflowing. Are there any
>     settings to
>     > >>> allow
>     > >>> the data to come across as bigint or strings?
>     > >>> For example:
>     > >>> {"type":"Feature","properties":{"mag":0.46,"place":"2km W of
>     Lemmon
>     > >>> Valley,
>     Nevada","time":1375291903959,"updated":1375295733317,"tz":-420,"url":"htt
>     > >>> p://earthquake.usgs.gov/earthquakes/eventpage/nn00419191
>     <http://earthquake.usgs.gov/earthquakes/eventpage/nn00419191>","detail":"http:
>     //earthquake.usgs.gov/earthquakes/feed/v1.0/detail/nn00419191.geojson
>     <http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/nn00419191.geojson>","f
>     elt":null,"cdi":null,"mmi":null,"alert":null,"status":"REVIEWED","tsunami
>     ":null,"sig":3,"net":"nn","code":"00419191","ids":",nn00419191,","sources
>     ":",nn,","types":",cap,general-link,geoserve,nearby-cities,origin,","nst"
>     :12,"dmin":0.069,"rms":0.1034,"gap":74,"magType":"ml","type":"earthquake"
>     },"geometry":{"type":"Point","coordinates":[-119.8773,39.632,5.0829]},"id
>     > >>> ":"nn00419191"}
>     > >>> Gets returned as
>     > >>> OGRFeature(OGRGeoJSON):176
>     > >>>    mag (Real) = 1.7
>     > >>>    place (String) = 21km S of Lowell, Oregon
>     > >>>    time (Integer) = 902732480
>     > >>>    updated (Integer) = 903846662
>     > >>>    tz (Integer) = -420
>     > >>>    url (String) =
>     > >>> http://earthquake.usgs.gov/earthquakes/eventpage/uw60561592
>     > >>>    detail (String) =
>     http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/uw60561592.geojso
>     > >>> n
>     > >>>    felt (String) = (null)
>     > >>>    cdi (String) = (null)
>     > >>>    mmi (String) = (null)
>     > >>>    alert (String) = (null)
>     > >>>    status (String) = REVIEWED
>     > >>>    tsunami (String) = (null)
>     > >>>    sig (Integer) = 44
>     > >>>    net (String) = uw
>     > >>>    code (String) = 60561592
>     > >>>    ids (String) = ,uw60561592,
>     > >>>    sources (String) = ,uw,
>     > >>>    types (String) =
>     > >>>    nst (Integer) = (null)
>     > >>>    dmin (Real) = 0.24254513
>     > >>>    rms (Real) = 0.24
>     > >>>    gap (Real) = 118.8
>     > >>>    magType (String) = Md
>     > >>>    type (String) = quarry
>     > >>>    POINT (-122.7927 43.7262 0)
>     > >>> _______________________________________________
>     > >>> gdal-dev mailing list
>     > >>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     > >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>     > >> Try the cast operator in ogr sql:
>     > >> kyle at kyle-workstation:~$ ogrinfo -sql 'select *, cast(time as
>     > >> character(0)),cast(updated as character(0)) from OGRGeoJSON'
>     /vsicurl/http://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_day.
>     > >> geojson
>     > >> OGRFeature(OGRGeoJSON):185
>     > >>   mag (Real) = 2.4
>     > >>   place (String) = 29km N of Brenas, Puerto Rico
>     > >>   time (Integer) = 905049680
>     > >>   updated (Integer) = 908474945
>     > >>   tz (Integer) = -240
>     > >>   url (String) =
>     > >> http://earthquake.usgs.gov/earthquakes/eventpage/pr13212004
>     > >>   detail (String) =
>     http://earthquake.usgs.gov/earthquakes/feed/v1.0/detail/pr13212004.geojson
>     > >>   sig (Integer) = 89
>     > >>   net (String) = pr
>     > >>   code (String) = 13212004
>     > >>   ids (String) = ,pr13212004,
>     > >>   sources (String) = ,pr,
>     > >>   types (String) =
>     ,cap,geoserve,nearby-cities,origin,tectonic-summary,
>     > >>   nst (String) = 13
>     > >>   dmin (Real) = 0.30722383
>     > >>   rms (Real) = 0.27
>     > >>   gap (Real) = 219.6
>     > >>   type (String) = earthquake
>     > >>   time (String) = 905049680
>     > >>   updated (String) = 908474945
>     > >>   POINT (-66.3495 18.7346 29)
>     > >> note the values at the bottom, time and update as (String).
>      You could
>     > >> write the entire field list in  the sql and substitue time
>     and updated
>     > >> for the casted values.
>     > >> kss
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> <http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130802/9dbe7f8b/attachment.html>
