[gdal-dev] OGDI dead?
Volker Fröhlich volker27 at gmx.at
Mon Aug 5 08:21:25 PDT 2013
On 05/08/13 06:26, Frank Warmerdam wrote:
> William,
> Interesting point.  It would appear I'll need to do a few small fixes to
> OGDI to keep it building, though I normally just work around the
> projects.h one.  In fact, I'm only vaguely familiar with the existance
> and role of libdtusa.so so perhaps that has been broken for a while too.
> Best regards,
> Frank
> On Sun, Aug 4, 2013 at 11:44 AM, William Kyngesburye
> <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>     Odd, it's working now.  Though I'm guessing that it will fail if it
>     tries to load libdtusa.so to do a datum transform (or whatever it
>     does with libdtusa.so).  Is this even possible from GDAL?
>     On Aug 4, 2013, at 12:23 AM, William Kyngesburye wrote:
>      > When doing some dependency updating for my GDAL I noticed that
>     OGDI stopped working, and it looks like it's because of a change in
>     PROJ 4.8 - not only was the projects.h removed from installation,
>     but the nad_init call changed (ie binary incompatibility).
>      > There hasn't been a release since the 3.2 beta 2 in 2008, and
>     neither has the cvs source on Sourceforge been updated.  There is a
>     bug report there about this PROJ issue from over a year ago.
>      > Will this ever be fixed?  Is there a simple patch to fix it?
>     William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>     http://www.kyngchaos.com/
>     All generalizations are dangerous, even this one.
For reference:
https://bugzilla.redhat.com/show_bug.cgi?id=816282
Volker
