[gdal-dev] problem with importing gml file to PostGIS with ogr2ogr
Even Rouault even.rouault at mines-paris.org
Tue Aug 6 00:18:31 PDT 2013
Selon Piotr Pachó <piotrpachol at gmail.com>:
> Thanks for your explanations but I still can't import polygons which
> contains many vertices.
> I do some test with polygons which contains different quantities of
> vertices and
> on my computer and configuration I can import polygon which has 2046
> pairs (x,y) of coordinates
> but I can't import when it has 2047 pairs and more.
> The length of hex string which is created in attribute
> geometry(Geometry,2180)
> can't be longer than 65534 chars.
> Where eventually to change  some configurations variables of PostGIS or
> Postgres or ogr2ogr ?
> Do you have any other suggestion ?
I don't reproduce such limitations with the following script :
from osgeo import ogr
ls = 'LINESTRING('
for i in range(60000):
    if i != 0:
        ls = ls + ','
    ls = ls + "%d %d" % (2*i,2*i+1)
ls = ls + ')'
ds = ogr.Open('pg:dbname=autotest', update=1)
lyr = ds.CreateLayer('biggeom', geom_type = ogr.wkbLineString, options =
['OVERWRITE=YES'])
feat = ogr.Feature(lyr.GetLayerDefn())
feat.SetGeometry(ogr.CreateGeometryFromWkt(ls))
lyr.CreateFeature(feat)
feat = None
ds = None
ds = ogr.Open('pg:dbname=autotest')
lyr = ds.GetLayerByName('biggeom')
lyr.ResetReading()
feat = lyr.GetNextFeature()
feat.DumpReadable()
My config :
POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012"
GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0" LIBJSON="UNKNOWN" RASTER
PostgreSQL 9.1.9 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu/Linaro
4.6.3-1ubuntu5) 4.6.3, 64-bit
> Piotr
> W dniu 2013-08-05 22:19, Even Rouault pisze:
> >> Hello list,
> >> I have problem with importing gml file (with polygons) to postgis using
> >> standard ogr2ogr command which look like:
> >> ogr2ogr -a_srs EPSG:2180 -f "PostgreSQL" PG:"host=localhost
> >> user=postgres dbname=test password=postgres port=5432"
> >> d:\test\BDOT10k\OT_ADJA_A.xml
> >> I tried to import two GML files (with xsd schema necessary):
> >> - OT_ADJA_A.xml -  is orginal valid xml file - after import to Postgis a
> >> table is created but geometry column is empty,
> >> - OT_ADJA_A_changed.xml - is changed and not valid xml file - but after
> >> import to Postgis a table is created and some records have geometry, the
> >> other not.
> >> All files are accessible here:
https://drive.google.com/folderview?id=0B54CPoAEcivYOTZhNDlpU3hkTlk&usp=sharing
> >> So I have the following questions:
> >> 1. In file OT_ADJA_A.xml  Why aplication not recognize <ot:geometria>
> >> element which is "gml:PolygonType" type ? (there is definition in
> >> OT_BDOT10k_BDOO.xsd file)
> > Because the OGR GML driver has limited support to parse .xsd files. The
> .xsd
> > should be just near the .xml file, and with the same basename. But even if
> it
> > was the case, it is just not smart enough to realize that <ot:geometria>
> must be
> > a "gml:PolygonType"
> >> 2. In file OT_ADJA_A_changed.xml I replace <ot:geometria> with
> >> <gml:Polygon>. Why in that case some of records are imported with
> >> geometry and the other not ?
> > I don't see that problem. In the sample you've provided, there are 6
> features
> > with geometries and the 6 are imported into PostGIS with their geometries
> >> 3. Is there any constraints of Postgis or ogr2ogr in quantity of
> >> vertices which can have a Polygon ?
> > No, you're only limited by the size of virtual memory (and possibly a
> PostgreSQL
> > limit on the size of records or fields)
> >> I will appreciate any help.
> >> Regards,
> >> Piotr
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
