[gdal-dev] Upgrade Python GDAL package in pypi
Howard Butler howard at hobu.co
Sun Aug 11 13:33:34 PDT 2013
On Aug 6, 2013, at 10:57 AM, Ricardo Filipe Soares Garcia da <ricardo.garcia.silva at gmail.com> wrote:
> Hello list
> I have been using GDAL Python bindings inside a virtualenv on some ubuntu-server 12.04 machines to do geoprocessing tasks.
> I have an automated script to setup GDAL from the ubuntugis repository and then use pip to get the Python bindings code (from pypi) and execute setup.py with the correct gdal paths and compile the bindings. It used to work nicely.
> Unfortunately, now that GDAL 1.10 is out and the ubuntugis folks have upgraded their GDAL, I cannot do this anymore, because the pypi version of GDAL is still at 1.9.1.
> I'd like to kindly request that the package available in the python package index be upgraded to version 1.10 too.
> Thanks
Ricardo,
I have updated the PyPI package to 1.10. We should probably make this part of our regular packaging tasks, as it is very much a one-off thing that I do manually for releases at this time. If Even or any of the other GDAL devs have PyPI logins, please let me know, and I'll add you to the maintainer list so you can push new releases.
Howard
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130811/1bfd6125/attachment.pgp>
