[gdal-dev] QGIS hanging when opening a FileGDB on 64 bit Linux
Even Rouault even.rouault at mines-paris.org
Tue Aug 13 00:23:59 PDT 2013
Selon Jeremy Palmer <JPalmer at linz.govt.nz>:
> Wow Even - just amazing as always.
> Have you confirmed that you can no open a FileGDB in QGIS?
No, I didn't. I've tested with the OGR API that it solved the issue with the
following access pattern :
ds1 = ogr.Open(datasetname)
ds2 = ogr.Open(datasetname)
ds2 = None
ds1 = None
> I still get the
> freeze when using GDAL trunk, but maybe that now a QGIS problem.
Just to be sure that you are using the version with the fix, if you break with
gdb when it hangs, does it display FGdbDriver::Release() in the stack trace ?
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Tuesday, 13 August 2013 11:29 a.m.
> To: gdal-dev at lists.osgeo.org
> Cc: Jeremy Palmer; 'qgis-developer at lists.osgeo.org'
> Subject: Re: [gdal-dev] QGIS hanging when opening a FileGDB on 64 bit Linux
> Le lundi 12 août 2013 22:12:11, Jeremy Palmer a écrit :
> > Further to this I see that when you open a FIleGDB in QGIS 3 OGROpen
> > calls made to the same database before any OGR_DS_Destroy calls are
> > made. These open calls occur during the layer selection dialog, the
> > OGR provider construction, and the initialisation of the
> QgsOgrFeatureIterator.
> > I'm guessing the fix for this should really be done at the Esri
> > library level, but because we have no control over this maybe
> > something can be done in the OGR library to reuse FileGDBAPI Geodatabase
> handles?
> Jeremy,
> I do think this is exactly the issue of
> http://forums.arcgis.com/threads/76527-CloseDatabase-hanging-on-64-bit-Lin
> ux- when-same-File-Geodatabase-opened-twice
> At least I reproduced it on my own PC. I've implemented a workaround in GDAL
> trunk for that issue that implements ref-counting of the FileGDBAPI Geodabase
> handle at OGR side : http://trac.osgeo.org/gdal/changeset/26307.
> Even
> > Cheers,
> > Jeremy
> > From: Jeremy Palmer
> > Sent: Sunday, 11 August 2013 9:08 a.m.
> > To: qgis-developer at lists.osgeo.org
> > Subject: QGIS hanging when opening a FileGDB on 64 bit Linux
> > Hi QGIS devs!
> > Since the latest round of code changes (maybe over the last 2 months)
> > I can no longer open Esri FileGDB in QGIS. I can read the database and
> > QGIS prompts me from the FileGDB layers to add to the map, but when I
> > select the layer from this dialog QGIS just hangs. I did some
> > debugging and it seems to hang on the OGR_DS_Destroy call within
> > QgsOgrFeatureIterator::close(). Does anyone else have this problem?
> > I'm running FileGDB SDK 1.3 and Ubuntu 12.04 64bit with QGIS master.
> > I've tested this with the OSGeo4W win32 qgis-dev package and I don't
> > get the problem.
> > Could this be related to this issue:
> > -Lin ux-when-same-File-Geodatabase-opened-twice
> > Cheers,
> > Jeremy
> > This message contains information, which is confidential and may be
> > subject to legal privilege. If you are not the intended recipient, you
> > must not peruse, use, disseminate, distribute or copy this message. If
> > you have received this message in error, please notify us immediately
> > (Phone 0800
> > 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> > accepts no responsibility for changes to this email, or for any
> > attachments, after its transmission from LINZ. Thank You.
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Geospatial professional services
> http://even.rouault.free.fr/services.html
> This message contains information, which is confidential and may be subject
> to legal privilege. If you are not the intended recipient, you must not
> peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800 665
> 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no
> responsibility for changes to this email, or for any attachments, after its
