[gdal-dev] OGRStyleLabel/OGRStyleTool units
    Andre Vautour
    andre.vautour at caris.com
    Tue Aug 13 04:38:38 PDT 2013
I am trying to interpret font sizes coming from OGR feature style strings.
I would expect a font size in ground units to be scale-dependent
inasmuch as a label would get smaller when you zoom out and bigger when
you zoom in. I would expect a font size in pts, mm, inches, pixels, etc.
to be scale-independent and to be drawn with that size at the current
display scale.
The problem I have encountered is that the style tools do not seem to
offer a way to get at the input units (OGRStyleValue::eUnit) of a given
parameter. The classes only seem to offer a way to convert the values
from their unexposed input units to some given output units.
Is there a way to get at that information? If not, would it make sense
to add a GetInputUnit(Param) method on the OGRStyleTool classes?
OGRSTUnitId GetInputUnit(OGRSTLabelParam eParam, GBool &bValueIsNull);
I have also considered trying to use SetInternalInputUnitFromParam to
work around the problem at my level, but I cannot seem to get at the
original parameter string as GetParmStr gives back a unit-converted string.
Thanks,
Andre
Any views or opinions expressed in this email are solely those of the
author and do not necessarily represent those of the company. No binding
contract will result from this email until such time as a written
document is signed on behalf of the company.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130813/d3ef93ea/attachment.html>
