[gdal-dev] GDAL 1.10.1 release schedule ? [Was Re: QGIS hanging when opening a FileGDB on 64 bit Linux]
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Aug 14 00:40:05 PDT 2013
Even Rouault <even.rouault <at> mines-paris.org> writes:
> > > GDAL users,
> > > if you have fixes they'd like to see in 1.10.1, then it would be time to
> > speak
> > > up, but preferably with a ticket with an attached patch
> > I think there never was a ticket about adding support for reading the GML
> > variant of the National Land Survey of Finland. This was implemented in
> > http://trac.osgeo.org/gdal/changeset/26140
> > I suppose this enhancement will be included in 1.10.1 and in QGis 2.0 but I
> > would like to be sure. It might also be worth advertising MTK-GML support
> > in the GDAL release announcement.
> Hi Jukka,
> this enhancement was done in trunk (GDAL 2.0), and not in the 1.10 branch
that
> will be the starting point for 1.10.X. Looking at the size of the changeset,
> I'm a bit concerned about backporting it into the 1.10 branch as well.
> Pending GDAL 2.0 release (don't ask me when ),  binary builds tagged "-
> development" at http://www.gisinternals.com/sdk/ can already be used to
> convert MTKGML to other formats.
Hi Even,
Ok, this is understandable but a bit sad for the Finnish QGis users because
it seems to be a huge job to build QGis with updated GDAL version, at least
for Windows. But no worry, command line GDAL from trunk is easy to acquire
and suits well for most MTKGML users.
-Jukka-
> Even
