[gdal-dev] gdal - grass 7 (conf)
Martin Landa landa.martin at gmail.com
Wed Aug 14 04:54:52 PDT 2013
Hi Even,
2013/8/14 Even Rouault <even.rouault at mines-paris.org>:
>> I fixed compilation issues related to GRASS 7 in r26318. There are
>> some modifications in `configure` script [1] which I haven't committed
>> yet.
> Cool.  Just a question. I see $(PG_INC) in the GNUmakefile : just curious why
> it is needed ?
>> Is it ok if I generate `configure` script using `autoconf` (having
>> version 2.69) and commit the change together with `configure.in`?
> Yes please do so. I've just regenerated configure from the current configure.in
> with autoconf 2.69, and committed it (r26319), so that your commit doesn't mix
> autoconf version upgrade and your changes.
thanks a lot, applied in r26320. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
