[gdal-dev] Problem with gdal/swig/plugins
Even Rouault even.rouault at mines-paris.org
Fri Aug 16 12:17:06 PDT 2013
Le vendredi 16 août 2013 21:08:44, jim hopper a écrit :
> Sorry I just passing this on for a coworker,
> Gdal 1.9.2 and SWIG is 2.0.10
I've just tested with SWIG 2.0.10 (and GDAL trunk, but the bindings have not
fundamentally changed recently) and it works. I believe your issue is not
related to SWIG but rather to a general issue with the .dll / .so not being
accessible by Java. See
http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructions or
http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
> Thanks jim
> On 8/16/13 2:58 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> > Le vendredi 16 août 2013 20:33:57, jim hopper a écrit :
> >> Is there any limitations on which version of swig can be used with gdal.
> >> We are running into problems where our java code can¹t find the gdal
> >> plugins.
> > When you ask a question about versions, it is good to say which version
> > you are using...
> > They work fine with swig 1.3.40 and swig 2.0.8
> > Which one are you trying ?
> >> 15:35:27,055 WARNING [it.geosolutions.imageio.gdalframework]
> >> (http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: DTED
> >> Cause: java.lang.UnsatisfiedLinkError:
> >> org.gdal.gdal.gdalJNI.SWIGDriverUpcast(J)J
> >> This is not a problem unless you need to use the specified GDAL plugin.
> >> It won't be enabled
> >> 15:35:27,076 WARNING [it.geosolutions.imageio.gdalframework]
> >> (http--0.0.0.0-8442-3) Failed to get the specified GDAL Driver: JP2KAK
> >> It won't be enabled
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Jim  Hopper |
> Software Application Engineer IV | National Security Sector | Integrated
> Systems Group
> 3745 Pentagon Blvd,
> Beavercreek, OH 45431
> Phone: 937-431-2336 | Mobile: 937-367-7252
> James.e.hopper at saic.com <mailto:james.e.hopper at saic.com>
> NATIONAL SECURITY |  HEALTH  |  ENGINEERING
> Science Applications International Corporation
> This email and any attachments to it are intended only for the identified
> recipients. It may contain proprietary or otherwise legally protected
> information of SAIC. Any unauthorized use or disclosure of this
> communication is strictly prohibited. If you have received this
> communication in error, please notify the sender and delete or otherwise
> destroy the email and all attachments immediately.
Geospatial professional services
http://even.rouault.free.fr/services.html
