[gdal-dev] ogr2ogr
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Aug 23 02:10:49 PDT 2013
Shalini,
You can use the -wrapdateline option in ogr2ogr to split the geometries
crossing the dateline meridian. You can fine-tune it with the
-datelineoffset option.
On Fri, Aug 23, 2013 at 12:46 PM, Shalini <shalinitoleti at gmail.com> wrote:
> Hi Chaitanya,
> Willyou please let me know:
> How do we correct geometry  which cross the meridian for a shp file using
> ogr command.
> Splitting the polygon using ogr command.
> Thanks in Advance,
> Shalini
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130823/1de0be4b/attachment.html>
